New Project with Mesa 7I96 and THCAD-05
- Thank you received: 4151
25 Jul 2021 01:09 #215828
Replied by rodw on topic New Project with Mesa 7I96 and THCAD-05
Yeh, I was hoping to run his config up on a 7i76e and sort it out for him. If QTplasmac behaves for me on another PC I have at home..It kinda defeats the whole purpose of a machine hal and a custom hal.
- acourtjester
- Thank you received: 29
26 Jul 2021 14:32 #215958
by acourtjester
Replied by acourtjester on topic New Project with Mesa 7I96 and THCAD-05
You would be best served having custom hal code in custom.hal rather than your main hal file, that way your main hal file can still be changed by pncconf.
You seem to be missing the loadrt and addf lines.
I'm following the instruction given. I'm a rookie so don't venture out to much. My approach is to tackle one item at a time. One of the videos I watched stated to start with a basic config and then change it as you go along to expand operations. I had a good start and when back to add/change home/limits switches configuration and that blew it up and I had to start over. Now I build a bogus configuration file to copy the changes from it to the one I am using. I did not know where the other encode selection was, so thanks for pointing that to me. When I get to the point of cutting metal with the ohmic sensor and the THC working I will be happy and stop asking questions. Thanks again Tom
If needed I will copy the whole folder that has the Machine name and zip and attach it here.
- snowgoer540
- Thank you received: 907
26 Jul 2021 14:47 #215960
by snowgoer540
There's a nice "BACKUP CONFIG" button in the UTILITIES section of the PARAMETERS Tab that does this all for you, and copies all the necessary stuff (in addition to the version number, etc.) for us to make helping you easier.
You can also use it to make a handy backup of the entire QtPlasmaC setup once you get it the way you want it.
A quick read about it can be found here (if you're interested): linuxcnc.org/docs/devel/html/plasma/qtplasmac.html#qt_backup
Replied by snowgoer540 on topic New Project with Mesa 7I96 and THCAD-05
- acourtjester
26 Jul 2021 16:30 #215964
by acourtjester
here is the compressed config file from the system today. At this point I have not enabled the second encoder as PhillC had instructed, but will do that today.
Rod the "E" stop works perfectly, homed the axis and hit the "E" stop and both the Power and "E" stop buttons went out. reset the switch and back running Thanks.
- snowgoer540
26 Jul 2021 17:12 #215968
by snowgoer540
That looks like the log file.
If you clicked the backup config button, it would have dumped a .tar.gz file in your home directory.
<machine_name>_<version>_<date>_<time>.tar.gz
So something like:
plasma_V1.0.56_21-07-26_10_23_39.tar.gz
So something like:
- acourtjester
26 Jul 2021 19:04 #215976
by acourtjester
Sorry rookie mistake
- acourtjester
26 Jul 2021 20:05 #215981
by acourtjester
The addition of the encoder selection in the Pncconf to the Hal file made no change to the voltage display. Attaching a 9 volt battery to the Arc voltage input is still only shown in Hal show. I am using a connector to the controller with only the Arc OK and Arc voltage connection. I connect the wires for Arc Ok together and then attach the wires to the 9 volt battery for testing the signals. It is not connected to my Hypertherm, as I do not think that would make any difference.
26 Jul 2021 20:40 #215986
Tom, you do not have these settings configured
I did ask earlier but on the back your two THCAD boards, there is a white sticker. Can you post up these two values for both boards please?
I'll have a look at it for you tonight but its 6:30am here so it will be a while...
Arc Voltage Offset = 0
Arc Voltage Scale = 1I did ask earlier but on the back your two THCAD boards, there is a white sticker. Can you post up these two values for both boards please?
- snowgoer540
26 Jul 2021 23:18 #215993
by snowgoer540
In "toms_test.hal", you need to uncomment this line (remove the #):
in "custom.hal", the following two lines are redundant, delete them (they are in toms_test.hal already):
in "custom.hal, add the following line:
As Rod pointed out, your Voltage Scale and Voltage Offset need to be set. They are located in the ARC section of CONFIGURATION section on the PARAMETERS tab. You can use the numbers on the white label on the rear of the THCAD for the arc voltage and this calculator to get the values: jscalc.io/calc/NTr5QDX6WgMThBVb
Also, double check that the values for these lines in "custom.hal" match the white label on the back of the OHMIC THCAD:
I did attach the updated files as well for the changes I mentioned at the top.
#net plasmac:arc-voltage-in => plasmac.arc-voltage-inin "custom.hal", the following two lines are redundant, delete them (they are in toms_test.hal already):
setp hm2_7i76e.0.encoder.00.scale -1
setp hm2_7i76e.0.encoder.00.counter-mode 1in "custom.hal, add the following line:
setp hm2_7i76e.0.encoder.01.filter 1As Rod pointed out, your Voltage Scale and Voltage Offset need to be set. They are located in the ARC section of CONFIGURATION section on the PARAMETERS tab. You can use the numbers on the white label on the rear of the THCAD for the arc voltage and this calculator to get the values: jscalc.io/calc/NTr5QDX6WgMThBVb
setp ohmicsense.thcad-0-volt-freq 138300
setp ohmicsense.thcad-max-volt-freq 966400I did attach the updated files as well for the changes I mentioned at the top.
- phillc54
- Thank you received: 2100
26 Jul 2021 23:24 #215994
by phillc54
Replied by phillc54 on topic New Project with Mesa 7I96 and THCAD-05
If you use PnCconf on an existing config and add an arc voltage enoder it will put the required scale and offset values in a file ending in "new" in the config directory.
Time to create page: 0.165 seconds
