  • rajsekhar
  • rajsekhar
27 Aug 2024 08:53
Error while Running Linuxcnc was created by rajsekhar
Category: Driver Boards
I am using Mesa 7i92+7i76+7i84.
Machine is under software set up stage, wiring completed.
I encountered the attached error in photo. The system runs ok, but it is 4 or 5th occasion the error occured.
What is happening wrong? Is it softw
  • rodw
  • rodw's Avatar
27 Aug 2024 08:31
Ethercat installation from repositories - how to step by step
Category: EtherCAT
Looks like ARM is not supported in their repo; You will need to compile from source
  • rodw
  • rodw's Avatar
27 Aug 2024 08:20
Replied by rodw on topic Is there an easy way to swap axes?
Using separate configs, the only thing needed is to change the coordinates statement in the ini file eg XYYZ to YXXZ which I did on a machine yesterday.
But stupidly, pncconf and stepconf set all of the signals to axes instead of joints.What I do is to relabel the signals to avoid confusion eg x-home becomes 0-home. I made 162 changes.
I have thought of modifying pncconf to select between joint based and axes based configs.
  • Aciera
  • Aciera's Avatar
27 Aug 2024 08:08 - 27 Aug 2024 08:09
Replied by Aciera on topic durchmesser stimmt nicht
Category: Other User Interfaces
1. du hast mehrere configs gepacktm, bitte nur den ordner wo deine ini und hal Dateien drin sind, um die es hier geht (I vermute mal es ist der Ordner 'probe_tab').
2. Im gezippten Ordner 'probe_tab' gibt es zwar eine Datei 'probe-tab.ini' aber in der gibt es unter [HAL] keine Zeile 'HALUI = halui':
3. Gemäss deinem Fehler könnest du allerdings die Zeile eingefügt haben aber mit einem Schreibfehler ('halu' statt 'halui'):
Can't execute halui program halu
4. Also mal deine aktuelle ini auf den Schreibfehler prüfen.
  • Mecanix
  • Mecanix
27 Aug 2024 08:07 - 27 Aug 2024 08:09
Replied by Mecanix on topic XHC WHB04b-6 - Disconnects / freezes?
Category: Basic Configuration
Alright a few other related forum posts (forum.linuxcnc.org/gmoccapy/34296-xhc-hc04-lost-connection, forum.linuxcnc.org/38-general-linuxcnc-q...-hb04-pendant-issues) convinced me to upgrade LinuxCNC, which appears to have solved the issue.
I upgraded from 2.8 to 2.9.3.
I have the same MPG, which I only use for the macro buttons for when I'm far from the controller and doing manual fixture setup and other non-automation related tasks. Regardless of the Lcnc version that MPG is near if not close to being useless. Similar to the keyboard, it's quite dangerous ($$$) I would like to add. There is no CRC neither data integrity to that thing and so, don't complain if it decides to randomly wander either sides and crash your >5k worth spindle into something... you get the idea.
A safe & honest MPG requires to be hard wired. Only hardware that is legally allowed to move my axis here (no keyboard, no wifi, nothing else).
  • CTB_le123
  • CTB_le123's Avatar
27 Aug 2024 07:42
The machine is choppy when using MPG was created by CTB_le123
Hello!
    I installed the LinuxCNC on my machines. When using MPG, the machine shakes violently. I referred this  [topic][www.forum.linuxcnc.org/38-general-linuxc...choppy-motion#299365].
Set the axis.N.jog-accel-fraction 0.5   One machine goes well, but the other doesn't work. I use the ilowpass to them, it can run smoothly, but it will be very 'lazy'. Even I stop the MPG, the axis still run. I set ilowpass.scale 0.9   ilowpass.gain 0.85 . Now I want to know is there other methods to salve it.
I appreciate you for your replay.
  • karlhe
  • karlhe
27 Aug 2024 07:35
Replied by karlhe on topic durchmesser stimmt nicht
hallo,
ich bewundere deine geduld... aber mit 78 jahren geht alles langsamer...bei mir..
die config gepackt, Halui=halui eingefügt, fehlermeldung neu zugefügt..
karlhe
  • phillc54
  • phillc54's Avatar
27 Aug 2024 07:03
Replied by phillc54 on topic #<holes> = 3 - Unexpected behaviour
Category: Plasmac
I am probably barking up the wrong tree but could you try with the following lines disabled in their respective files:
Plasma.ini:   HALFILE = plasma_gamepad.hal
Plasma.hal:   loadusr -W hal_input -KRAL Gamepad
  • mighty_mick
  • mighty_mick's Avatar
27 Aug 2024 07:01
What's the Oddest Machine You Have Powered with LinuxCNC
I wanna ask a question. What are you using as controller?(SBC or normal computer). Since i didn't setup a machine with normal computer, i am wondering about this topic. I usually worked with SBCs, so i didn't use parallel port or that kind of stuff. Is it hard, what do you think?
  • Aciera
  • Aciera's Avatar
27 Aug 2024 06:52 - 27 Aug 2024 06:52
Replied by Aciera on topic Modify Preview Default
To see hidden files in linux you usually have to type <ctrl>+h in the file manager
  • Aciera
  • Aciera's Avatar
27 Aug 2024 06:49
nicht den 'linuxcnc' ordner packen sondern deinen config ordner, so wie du es hier gemacht hast.
forum.linuxcnc.org/41-guis/53643-ease-pr...fuegt?start=0#308594
Aber wie gesagt erst die Zeile 'HALUI = halui' einfügen und nochmals probieren dann wären wir wieder einen Schritt weiter.
  • karlhe
  • karlhe
27 Aug 2024 06:19 - 27 Aug 2024 06:37
hallo,ich habe die config gepackt und versucht zu schicken,dass hat nicht geklappr.wahrscheinlich zu gross? karlhe
Nachtrag; ich habe den linuxcnc ordner kleiner gemacht, die config gepackt, läßt sich nicht einfügen
  • Aciera
  • Aciera's Avatar
27 Aug 2024 06:14
Na wenigstens der Fehler...
Hab ich doch schon geschrieben:
forum.linuxcnc.org/41-guis/53643-ease-pr...fuegt?start=0#308610
Du scheinst die Zeile aber nicht hinzugefügt zu haben.
  • karlhe
  • karlhe
27 Aug 2024 06:11
Hallo,
hier die dateien...
karlhe
  • Aciera
  • Aciera's Avatar
27 Aug 2024 06:05
Replied by Aciera on topic İnstall glade
İnstall glade
Category: Gmoccapy
To set a parameter through the gui you can simply add a function to your handler.
1. add the function 'on_value_changed' to your panel handler script like this (you will need to change the parameter name form 'near_speed.difference' to whatever parameter you want to change):
2. Open your panel in glade and add 'on_value_changed' as handler for the 'value_changed'  signal to your widget:
The parameter value should now change with the value of the panel widget:
Displaying 23146 - 23160 out of 24322 results.
Time to create page: 0.523 seconds
