  • DougM
  • DougM
13 Aug 2024 18:34
Replied by DougM on topic Mesa 7I92TM Parallel port pin mapping
Category: PnCConf Wizard
There is no breakout board - the K2 has a control box with a DB25F on the back. I could probably crack it open and see what it's running inside. From there I could likely re-route the lines to bring it back to "standard" pinouts. But it feels like this should be a .hal thing.
When you say "choose firmware" do you mean the firmware on the Mesa card?
Is this something I can configure via the Mesa Configuration Tool?
  • Obuhus
  • Obuhus
13 Aug 2024 18:06
Replied by Obuhus on topic Question: Gmoccapy 3.4.2 and touchscreen
Category: Gmoccapy
I agree. My project is in the stand stage on the table. But it works within its limits. However, It's not ok to not have a normal touch when it should be the default.
  • slowpoke
  • slowpoke
13 Aug 2024 17:54 - 13 Aug 2024 17:58
Jogging from Mesa input (Axis version 2.9.2)
Category: HAL Examples
I spent a fair bit of time getting a simple push-button to Mesa input to cause a jog x increment to occur. Google searches led to numerous threads with others struggling to get this seemingly simple thing to work. According to some of those posts, previous versions of LinuxCNC had a bug related to this and the method to cause a jog appears to have changed as well. So now that I have it working I decided to post what works for me and some of my incorrect assumptions along the way, with the goal of helping others not make the same mistakes I made.. I'm a bit of a newbie to all of this so if anything below appears incorrect please advise and I will correct.
Important things I learned:
1) There are a LOT of pins some with similar names, it helps to get a complete list for perusal:    PCW post=307558 userid=481
2) I assumed that the HAL jog related commands that I was adding to my postgui.hal file would effectively trigger the jog related GUI buttons in axis. My understanding now is that the halui pins are a completely different set of pins/parameters with no connection to the axis GUI buttons. So for example while testing, selecting an increment of say 0.01 in the Axis GUI does not set halui.axis.x.increment to 0.01. If you want an increment of 0.01 you need to explicitly add a line in your hal file to make that happen, for example setp halui.axis.x.increment 0.01.
3) The axisui pins don't exist until after the axis-gui has been loaded so all your hal code that requires pins from GUIs, like axisui pins, need to be in a postgui.hal file.
4) Before homing the motors are jogged as joints, after homing the motors are moved as axes.
5) Before using the halui jog pins ALL of the axis's need to be homed, not just the axis your trying to jog!
6) halui.axis.x.plus jogs continuously while activated, and halui.axis.x.increment-plus jogs by the previously specified increment (once per)
I have attached the relevant portion of my postgui.hal file as an example that works for me using Mesa input 3 as the trigger for a jog x + 0.1 increment.
File Name: postguiMes...tial.hal
File Size:1 KB
  • Limo
  • Limo
13 Aug 2024 17:38
Replied by Limo on topic Remora for RP2040
Remora for RP2040
Encoder support is also something I am looking to have. Then the rp2040 is then probably not the best option any more. How can I estimate the performance in terms of drive frequency for the axis?
  • PCW
  • PCW's Avatar
13 Aug 2024 17:33
Replied by PCW on topic Mesa 7I92TM Parallel port pin mapping
You cannot change the pinout of a specific firmware, you need
to choose firmware that matches the breakout you use.
You can change which stepgen runs which motion axis.
What breakout board do you need to support? For most
breakouts there are specific firmware files that match
their pinouts.
You can check pinouts by looking at the .pin files in the 7I92.zip
firmware distribution zip file (in /configs/hostmot2)
  • slowpoke
  • slowpoke
13 Aug 2024 17:08
Data transfer LinuxCNC to / from custom board - Solved
After a bit of trial and error I found the problem, I can now jog from the Arduino board. The fundamental problem was that I was not homing all axis's, I assumed because I was trying to jog x that homing x was sufficient.
I did a little test where I banged in 10 jog increments as fast as I could and none were lost. I'm not using a MPG so I can't comment on the slow response of the ArduinoConnector as noted by blazini36 when using a MPG, however for regular button presses it seems to be doing the job for me.
Thanks for the help getting this working.
Jeff
File Name: postguiArd...tial.hal
File Size:1 KB
  • DougM
  • DougM
13 Aug 2024 16:58
in PNCConf how do I assign a StepGen to the specific pins on the parallel port?
Background
I found myself with a K2 CNC router.  The parallel pinouts are non-standard
I was able to get it working in StepConf on an old machine with a built-in parallel port, but I wanted to get it running under the 7i92TM.  I have 2 other machines running with these cards.  I configured the card and cold-swapped it into one of the other machines and it worked perfectly.
But I must have just gotten lucky and the pin mappings were magically perfect on those other two machines because I can't find anywhere where I can assign the pins to the axes in PNCCONF.
I think it should be P2 on the attached PNG file, but on the far left column it says, "Num" 0, 1 and 2 and it assigns those to the stepgen.
But I can't figure out how to configure the StepGen to the specific pins.
I know it's some simple step I missed, but I'm totally wrapped around the axle on this.
Thank you,
  • royka
  • royka
13 Aug 2024 15:08
Dell Optiplex 3010 can't get PCI Parallel Port Card working
Perhaps the parport_pc module is loaded?
If it's PCIe you could try to disable the active state power management with the kernel parameter: pcie_aspm=off
Otherwise you could try another kernel, this is 6.10:
drive.google.com/drive/folders/1L28lG0zD...2XQJx?usp=drive_link
  • anfänger
  • anfänger's Avatar
13 Aug 2024 15:02
Replied by anfänger on topic Fehlmann Picomax 100 Retrofit
Category: Milling Machines
Yes! I am really happy that I've solved als the Hardware issues.
on the wiring todo list only open points are home and brake of the 4th axis.
And the Tool length sensor.
open software topics are:
migration to 2.9.3 maybe changing from probe_basic to qtdragon
Toolchange seqence
home with index.
Drive feedback
Nice to haves
Load feedback from drives and Spindle
Linear Scales for the Colum (Extension for Z Travel axis to compensate Tool length) To keep the Quill travel as short as possible and make the tool length sensor fully usable.
  • Lcvette
  • Lcvette's Avatar
13 Aug 2024 15:02
Py3 - Probe Basic Config Conversion Doc Lcnc 2.9+
Category: QtPyVCP
user tabs are in the sim config folder, you simply turn them on or off in the ini file, there is one for the main tab group and the side bar, so it pretty much covers you for being able to add any functionality you may need.
now it doesn't work if you are changing the main ui and need to add things in, but if you have a good idea for a change or addition you can alway voice that here or on the qtpyvcp chat.  we incorporate many ideas to make Probe Basic better often.  that is where many of the latest update changes came from, made to fix some shortcomings and add some feature functionality!.
Below is an image of the user tabs. those should also be available in the stable version.  you would simply edit those two files in qtdesigner and they are loaded on start up. this was they travel with your config and are never overwritten on updates.  you can nest tabs to make them infinitely deep to accomodate the most intesnse project additions.
Chris
  • cakeslob
  • cakeslob
13 Aug 2024 14:27
Replied by cakeslob on topic Remora for RP2040
Remora for RP2040
We would probably need to do some math to verify that it can provide the step speeds you need for all axis. I saw you mentioned something about an encoder, but rp2040 cannot do encoders if thats also what you need.
  • cakeslob
  • cakeslob
13 Aug 2024 14:21 - 13 Aug 2024 14:24
yes, you are right. I need to find the other excel sheet that raf made that had everything on it.
The problem is that it is the wrong board, using those pins in the config will cause problems for other users who use them. If all you need is a reference to which remora pin goes where, you can use the config file you loaded to the board. The part you need may be correct, but the pin assignment is not for the same board. If you use the STM32 pin names on your rt1052 board it will cause issues.
github.com/scottalford75/Remora-RT1052-c...xCNC/nvem-rt1052.txt
Ill even do you one better, here is a trimmed down list of the inputs/outputs that you can use that wont cause problems for other users.
Warning: Spoiler!
  • RLA
  • RLA
13 Aug 2024 14:14
Replied by RLA on topic Computer crashing
Computer crashing
Category: Installing LinuxCNC
I tried log path in terminal and got  "no such file or directory'??
  • mehdidadash
  • mehdidadash's Avatar
13 Aug 2024 13:59
Ethercat installation from repositories - how to step by step
Category: EtherCAT
if you mean this, "sudo udevadm control --reload-rules" , i have done it
also this one
sudo geany /etc/udev/rules.d/99-ethercat.rules
KERNEL=="EtherCAT[0-9]", MODE="0777"
  • Aciera
  • Aciera's Avatar
13 Aug 2024 13:34
Replied by Aciera on topic Ein Neuling sucht Hilfe
Category: Deutsch
Am besten du hängst mal deine .hal and .ini Dateien an.
Displaying 23956 - 23970 out of 24484 results.
Time to create page: 0.624 seconds
