  • scottlaird
  • scottlaird's Avatar
21 Aug 2024 17:07
Replied by scottlaird on topic CiA 402 in 1.15.0
CiA 402 in 1.15.0
Category: EtherCAT
Mind you, I don't *think* anyone has tested the ECR86 yet. I've been assuming that it's the same as the ECR60, just with more power. RTelligent is *mostly* predictable, but not entirely. For example, the "x2" models are kind of weird, probably because they're trying to cram a lot of features into a small controller, but the base ECR60 seems sane.
  • Aciera
  • Aciera's Avatar
21 Aug 2024 17:06
Replied by Aciera on topic 9 axis jog
9 axis jog
pncconf will likely only let you configure 4 axes so you would have to manually copy/modify the other 5 in the generated hal and ini files
  • nwallace
  • nwallace
21 Aug 2024 17:04
Post GUI HAL not loading and "Bad character '[' used" error on E-Stop
Category: QtPyVCP
Thank you very much for the help! I feel a bit lame for not realizing that you could only have one postgui_halfile. That has solved that issue.
As for the bad character issue, yes (abort, aborting) does trigger that error but only once instead of twice like an e-stop would.
  • DougM
  • DougM
21 Aug 2024 16:50 - 21 Aug 2024 16:50
Replied by DougM on topic Mesa 7I92TM Parallel port pin mapping
Category: PnCConf Wizard
Can you tell me what the name of the factory firmware is (.bin)?
I want to start all over again.
Also, is there somewhere that explains the difference between a .bin, .bit and .pin files?
Thank you,
  • Krulli_Fräser
  • Krulli_Fräser
21 Aug 2024 16:36
Replied by Krulli_Fräser on topic 7i97t with 7i84d connection problem
Category: Driver Boards
Final update on the topic:
a replacement 7i84 just arrived and I connected it in the same way. With the new card all inputs and outputs are working properly. I can see the card in halshow and it just works :)
  • AndyDM01
  • AndyDM01
21 Aug 2024 16:10
Replied by AndyDM01 on topic CiA 402 in 1.15.0
CiA 402 in 1.15.0
Category: EtherCAT
I will try to get my xml posted here tomorrow
the ECR86 say version 202!?
I started of by using rodw file he suggested
didn'work
after tried the ECR60 and did the modparameter stuff
afer tried the ECR86 and did the modparameter stuff
so far i only get errors
i believe you are at least 1 level up so i was hoping you could help
  • snowgoer540
  • snowgoer540's Avatar
21 Aug 2024 16:01
Replied by snowgoer540 on topic Straight cut error
Straight cut error
Category: Plasmac
Never mind, I see the issue here. I believe the root problem is that even though I clicked "CLEAR", it is attempting to load the file I had open prior to clicking CLEAR after the single cut is over, which may or may not be out of bounds. It shouldn't do that, I will look into what got screwed up and push a fix ASAP.
  • AndyDM01
  • AndyDM01
21 Aug 2024 16:00
  • AndyDM01
  • AndyDM01
21 Aug 2024 15:58
Replied by AndyDM01 on topic is there some basic list to build the net ?
Category: EtherCAT
it's you in the F16? small cockpit so im not sure F18 or F16 ...
  • AndyDM01
  • AndyDM01
21 Aug 2024 15:56
Category: EtherCAT
did read almost half of the linuxcnc documentation and i didn't see anything that would answer my question ... are there basic rules / commands to start from in linuxcnc-ethercat....
I have been tru all this shite 20+years ago when i tried to get a twincat controlled plc to work... doesn't look like the information base to get stuff working has improved... digging thru the twincat2 information was a pain in the ass... trying to find answers in this forum ... vage information
  • PCW
  • PCW's Avatar
21 Aug 2024 15:44 - 21 Aug 2024 15:45
Replied by PCW on topic Driver NUM GEC MK2S
Driver NUM GEC MK2S
That's probably expected.
You have about a 50% chance of an initial
runaway because the feedback direction is
wrong, that is you have positive feedback = runaway
rather than negative feedback = position control.
If the encoder direction is correct, you fix this by
changing the sign of the PWM scale.
  • schuetzbuilds
  • schuetzbuilds
21 Aug 2024 15:37 - 22 Aug 2024 12:33
Replied by schuetzbuilds on topic Retrofitting a MAHO MH600T
Category: Milling Machines
Uhhhh, I think you’ve hit the nail on the head… How embarrassing…The 7i84 is powered by a 24V field power, but it's connected to a completely separate 24V rail (24V Logic, marked in red), while the relay board is connected to a different 24V source (marked in blue) with no common ground between them. I’ll fix that tomorrow. Thank you!
EDIT: Yes, that was the issue. Now the coolant pump is working. And after fixing a small mistake in my hal the spindle is now also starting. Now only the gear train remains (and the fourth axis...)
  • garthnoakes
  • garthnoakes
21 Aug 2024 15:33
Logitech F310 shows in lsusb but HAL config does not show it - still strange
I have two identical PCs, same version (latest 2.9.3) of LinuxCNC, same F310.  One worked immediately - on the other, the F310 shows from lsusb (the output is identical on the first PC). But HAL config does not show the input pins on the second one.
I didn't do anything different in the installs.
Both are set to X mode
  • greg23_78
  • greg23_78
21 Aug 2024 15:31
Replied by greg23_78 on topic Driver NUM GEC MK2S
Driver NUM GEC MK2S
thank you, I hadn't noticed that was missing.
now, when activating the drivers, the motor goes into Z+ at high speed.
  • RLA
  • RLA
21 Aug 2024 15:30
9 axis jog was created by RLA
9 axis jog
Hi...new to linuxcnc...just got up and running but now am looking to set up panel that shows 9 axis that can be jogged... am using 7i96s mesa with firmware that supports 9 axis but am lost as to configure panel through pncconf..??
Thanks for any help!!
Rick
Displaying 22771 - 22785 out of 24953 results.
Time to create page: 0.382 seconds
