Feature Request
- phillc54
- Thank you received: 2100
- snowgoer540
- Thank you received: 907
All these issues "should" be fixed now in 2.8, master and the test branch.
Thanks Phill, much appreciated as always! I am planning to mess with my THC this evening so I'll report back if something is amiss
- snowgoer540
- phillc54
- snowgoer540
That is a problem of trying to integrate into existing GUIs. I could possibly do it with Axis but I doubt it I could do it with Gmoccapy.
Good thing I use Axis exclusively... the rest can bugger off!
- phillc54
- snowgoer540
I do regret supporting them both, it makes for a lot of extra work. I should have stuck with Axis...
I find gmoccapy to be extremely difficult to navigate.
At any rate, I think I found out why Tormach never answered my email about how they clear programs.
tormach.com/machines/plasma-tables.html
It seems we are in direct competition now
In all seriousness, I wonder if they are using @PCW's THCAD. It seems they use his hardware (in a modified to suite Tormach's needs) everywhere else, it wouldnt surprise me. Also, I wonder what they are doing for ohmic sensing.
Seems a bit pricey though.
- phillc54
Me too.I find gmoccapy to be extremely difficult to navigate.
Looks nice.At any rate, I think I found out why Tormach never answered my email about how they clear programs.
- snowgoer540
It will be neat to watch all it can do. And compare it to my home built table
- snowgoer540
#Torch voltage
setp hm2_[HOSTMOT2](BOARD).0.encoder.00.counter-mode true
setp hm2_[HOSTMOT2](BOARD).0.encoder.00.scale 1
setp hm2_[HOSTMOT2](BOARD).0.encoder.00.filter false
net rawtorchv hm2_[HOSTMOT2](BOARD).0.encoder.00.velocity scale.0.in
#Reading actual voltage
#5v calculation (half of the hv resistors shorted out)
#0v=96khz 5v=933khz
#0v to 5v = 837khz
#Gain = 5v/837000 hz =.00000597371/hz
#offset = .00000597371/hz * 96000hz * -1 = -.573476
# x50 gain = 0.0002986857
# x50 offset = -28.6738
setp scale.0.gain 0.0002986857
setp scale.0.offset -28.6738
net torchvolt scale.0.out
#filter voltage slightly
net torchvolt torchV-lowpass.in
setp torchV-lowpass.gain .1I find it interesting that they use the same calibration across all tables.
Which actually reminds me of a question. My voltage fluctuates a bit at idle, bounces around 0-3v. Should I apply a lowpass filter? I did tool around with the lowpass filter a bit, and it seems when I got it to stop bouncing around, it did nothing during a cut
At any rate, maybe it's not necessary.
