  • Carpio
  • Carpio
16 Aug 2026 19:21
Replied by Carpio on topic Retrofit of a Hitachi-Seike VK45 mill
Category: CNC Machines
Hi do you still have all the old boards from the VK45?
Andre 717-870-3719
16 Aug 2026 18:58
Replied by tommylight on topic Frage zu 7I96?
Frage zu 7I96?
Category: Deutsch
Auf die Mesa 7i96 manual (niht 7i96S):
  • Holzwurm56
  • Holzwurm56
16 Aug 2026 18:45
Replied by Holzwurm56 on topic Frage zu 7I96?
Frage zu 7I96?
Category: Deutsch
Hallo,
ich kann jetzt die Karte über Ethernet ansprechen und habe auch die 7I96_inmd.bit auf die Karte gespielt. Nur mal eine Frage für
die Zukunft: Gibt es eine Karte die so ähnlich wie 7I96 ist aber Eingangssignale von 24Volt verarbeiten kann?
MfG
Hans
  • GFC
  • GFC
16 Aug 2026 15:50
THC doesent work when G code is running
Category: Plasmac
while doing the first tests on my machine I noticed that THC doesnt work when the machine is running G code
I looked around and did some tests and it does work and move the z axis when I start a manual cut with f9 and jog with the arrow keys
QtplasmaC is getting arc voltage and arc ok signals
the G code im testing is the metric wrench and things from the conversational panel
the THC enabled light turns on but not the active light
it looks like the machine is getting up to the feed speed
how should i troubleshoot this and am I missing something obvious?
  • grandixximo
  • grandixximo's Avatar
16 Aug 2026 14:50
read if you have personal c or c++ components
Category: LinuxCNC Announcements
The HAL types and isolation work on master 2.10, changes how C/C++ components register and access pins and params: opaque refs with hal_get_*/hal_set_* accessors instead of direct volatile pointer dereference. The old API still builds (deprecations, not removals), so this is a migration window, if you need clarification please post here or better on
github.com/LinuxCNC/linuxcnc/discussions/4393
  • muddiver
  • muddiver
16 Aug 2026 08:57 - 17 Aug 2026 17:45
Help needed for conversion of old ( and loved ) Mach3 MPG
Category: Basic Configuration
Hi folks!
i try to get my loved MPG in action in Linuxcnc, but i struggle..
when i ask lsusb i get told its a:
ID 07c0:0115 Code Mercenaries Hard- und Software GmbH KeyWarrior Combo O Commander
when i ask cat /proc/bus/input/devices i get
[code]I: Bus=0003 Vendor=07c0 Product=0115 Version=0110
N: Name="Code Mercenaries KeyWarrior Combo O Commander"
P: Phys=usb-0000:2a:00.3-3.4.4/input0
S: Sysfs=/devices/pci0000:00/0000:00:08.1/0000:2a:00.3/usb3/3-3/3-3.4/3-3.4.4/3-3.4.4:1.0/0003:07C0:0115.0004/input/input13
U: Uniq=
H: Handlers=sysrq kbd event13 leds
B: PROP=0
B: EV=120013
B: KEY=1000000000007 ff800000000007ff febeffdfffefffff fffffffffffffffe
B: MSC=10
B: LED=1f
P: Phys=usb-0000:2a:00.3-3.4.4/input1
S: Sysfs=/devices/pci0000:00/0000:00:08.1/0000:2a:00.3/usb3/3-3/3-3.4/3-3.4.4/3-3.4.4:1.1/0003:07C0:0115.0005/input/input14
U: Uniq=
H: Handlers=mouse1 event14
B: PROP=0
B: EV=17
B: KEY=70000 0 0 0 0
B: REL=3
B: MSC=10
when i run "halrun" and type in:
loadusr -W hal_input Code Mercenaries KeyWarrior Combo O Commander
The keys get loaded, but they get loaded 5 times!
I am told that the name for the device is "Code Mercenaries KeyWarrior Combo O Commander" ,
but the message also shows 5 times!
What am i doing wrong?
Whats confusing to me too, is that i cannot use
loadusr -W hal_input "Code Mercenaries KeyWarrior Combo O Commander" , that one won't work, only without " , its accepted.
As far as i know, you should always use " when there are blanks in a name / path.
Thanks in advance, Tom
[/code]
  • Becksvill
  • Becksvill
16 Aug 2026 08:09
Replied by Becksvill on topic Colchester 4000L retrofit
Category: Turning
hey i just saw this and had to comment as i have been down this path about 10 times on big machines.
my experience when i looked into it was that using any of the fanuc stuff was just not worth it compared to new chinese servos. i use the Yuhai brand (have bought like 70 of them now)
a 2.2kw motor and drive 200v input power costs like 300 usd per axis. so 600 usd total. and you get new motors and drives that don't have issues. i tried keeping old electronics going too many times and it didn't work out for me. the i spent like 1000usd trying to fix old fanuc drives and then heidenhain fagor misubishi etc eventually i just come back to what i should have done in the first place and just bought new motors. anyway after 7 years and over 70 motors ranging from 400w up to 4.5kw i have only ever had one motor fail. and no drives and i think that was our fault with bearing misalignment the zaxis brake failed in it. But it is truely nice to just turn the machine on and know that it's just going to work.
also china has very nice vfd drives now you can get a 11kw drive for 200usd. or one that can turn a normal motor(like a pump farm motor even..) into a pretty rigid servo drive for about 900usd for 11kw
anyway let me know if you want any advice cheers
  • Becksvill
  • Becksvill
16 Aug 2026 08:00
Replied by Becksvill on topic Tool life tracking with tooldata
i am interested also in this as i have a large mazak horizontal cnc with a 80 pocket toolchanger and sister tools and tool time tracking will be nice so i will look at this when i get to it. machine is almost running cutting parts so close now
  • Becksvill
  • Becksvill
16 Aug 2026 07:58
Replied by Becksvill on topic Conversational CAD CAM
Category: O Codes (subroutines) and NGCGUI
yep no stress. hopefully as time goes on people will test this and use it. just would be a waste if it never got used. But i have 7 cnc machines myself that are getting the conversational stuff and a general upgrade of linuxcnc. and it's worth the time just for me so not too fussed if no one else uses this. machines are getting pretty cool now. with all the auto tool measure stuff it all makes a massive difference how fast jobs get done. and auto tool measuring means that i don't get the chance to make mistakes with tool offsets and they always stay loaded so i don't do any hacks. cause the fastest option is clicking measure and walking away to carry on programming on cam
cheers
  • Becksvill
  • Becksvill
16 Aug 2026 07:54
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
man this looks just like my place in NZ you get the machine bug and it bites hard aye lol. and then its more and more machines until its hard to stop
  • emresensoy
  • emresensoy
16 Aug 2026 07:48
Replied by emresensoy on topic DIY Robot Kinematic parameters,
First of all, thank you very much for your interest and support. The diagram you sent already formed my starting point. However, since there is a 90-degree difference between the slider joint and the next joint, I wanted to redo the calculations.
Also, since Genserkins only supports rotary axes, I will not be using it. I will recreate the kinematics according to my system.
  • Aciera
  • Aciera's Avatar
16 Aug 2026 07:35
Replied by Aciera on topic DIY Robot Kinematic parameters,
Is the DH parameters below right?
Those won't work. First indication is the simple fact that you are mixing distances and angles. Also note that genserkins uses 'modified DH' parameters not the standard 'DH' parameters.
I already posted the parameters for your robot that should work for your robot, why don't you start by trying those?
  • karlhe
  • karlhe
16 Aug 2026 05:24 - 16 Aug 2026 08:24
Replied by karlhe on topic radiusendpunkt nicht gefunden
Moin,
ich bin der Meinung, dass es nichts mit linuxcnc zu tun hat, sondern mit
fusion 360..?
Karlhe
Ich habe das Programm in fusion 360 mit dem Prozessor von estlcam rechnen lassen. der fährt die kontur ohne radius, dass hat
funktioniert. Der Postprozesseor von linuxcnc sollte beim abfahren von Konturen vielleicht doch noch überarbeitet werden.
  • viewsat
  • viewsat
16 Aug 2026 01:25 - 16 Aug 2026 12:20
The Linux CNC FPGA control board I bought connects to the motor driver, and it works perfectly with the 74HC245.
There is no problem connecting the DM542 using the 74HC245.
The FPGA (3.3V) is directly connected to the 74HC245 (5V).
  • dm17ry
  • dm17ry's Avatar
15 Aug 2026 21:00
Replied by dm17ry on topic Okuma encoders and drives
it's the data received by the controller from drives
Displaying 1501 - 1515 out of 12531 results.
Time to create page: 0.423 seconds
