  • Naols
  • Naols's Avatar
04 Aug 2025 10:28 - 22 Aug 2025 13:29
Replied by Naols on topic LinuxCNC and Beckhoff AX5000 servo drives
Category: EtherCAT
Thank you very much endian for this converter, I used it and the output "ethercat-conf.xml" file seems correct.
  • scsmith1451
  • scsmith1451's Avatar
04 Aug 2025 09:54
Replied by scsmith1451 on topic Set program zero using XY positioning laser
A question associated with this project to integrate a crosshair laser into my machine.
At present the crosshair laser has been successfully integrated into the gvcp panel. My next effort is to allow the user to select the coordinate system to set to zero given the position marked by the crosshairs on the stock. I've added a HAL_Combo box which I can select the coordinate system, however, while monitoring the s32 pin with show_configuration I do not see any change in the value of the pin when selecting a different value. I would like to reference both the label and value columns of the liststore associate with the selection. Is that possible without resorting to a handler?
  • mgm
  • mgm's Avatar
04 Aug 2025 09:34
Replied by mgm on topic Switch relay in a defined x position
Hi Benny,
Thanks for your message!
If I understand correctly, the HAL lines are the implementation of my current comp file, right?
I would now have to add the position switch and the query for the switch position and then connect it to the emergency stop if the position is incorrect.
Do I add the HAL lines to my existing HAL?
  • Abdulkareem
  • Abdulkareem
04 Aug 2025 09:17
Replied by Abdulkareem on topic Motion Jitter with LinuxCNC + EtherCAT
thank you again for your time the hal scope confirmed your hypothesis there is one thing i wanted to confirm if i tune the acceleration parameters will it reduce the noise because i think i might of set it a little bit high
  • Daroum
  • Daroum
04 Aug 2025 09:13
Modifying qtdragon screen was created by Daroum
Category: GladeVCP
Hello everyone
I want to create a new screen for a machine that i am working on
Qtdragon seems ideal for me but i need to modify it by deleting some sections that i don't need and adding other sections and buttons i already installed glade and also qt creator.
The board that am using ( mesa 7i76e) is in the machine and it's a bit far from me i couldn't use it for now so i can't create a project using my board configuration
So i need to create a modified qtdragon template or modifying the .ui file of the qtdragon template
When i create sim project based on qtdragon i couldn't find where i should make the modifications (.ui file doesn't exist in my project directory)
Anyone has an idea how to do that ?
Thanks in advance
  • Edi_48
  • Edi_48
04 Aug 2025 08:20 - 04 Aug 2025 08:21
7i96s Erweiterung was created by Edi_48
7i96s Erweiterung
Category: Driver Boards
Hallo  Ich habe eine Mesa7i96s und eine Mesa 7i84U welche Firmware muss ich flashen? Ich habe es mit sudo mesaflash --device 7i96s --addr 10.10.10.10 --write 7i96s_7i85sd.bit probiert aber ich sehe die Anschlüsse auf der 7i84u nicht
  • unknown
  • unknown
04 Aug 2025 08:05
Replied by unknown on topic Mesaflash is not able to find 5i25
This seems to be an issue that seems to happen with HP boxes, add in cards seem to be disabled. This is just not related to Linuxcnc cards. Users have had issues with PCIe LPT cards and a month or so ago when doing a google search related to this it pops up in HP forums with no resolution (not just the above mentioned add in cards). (sorry I didn't bookmark the threads I found)
  • unknown
  • unknown
04 Aug 2025 07:58
Replied by unknown on topic I've got a problem
I've got a problem
The user, langdons, really needs moderating, he is a bane to the forum.
  • GDTH
  • GDTH's Avatar
04 Aug 2025 07:55 - 04 Aug 2025 07:56
Replied by GDTH on topic Mesaflash is not able to find 5i25
I will dig more into tonight and see if i can find something from the bios. The only thing i can think of is that linuxcnc was installed with secure boot.
Properply end up doing a fresh start with linuxcnc.
I will update on this, if i find something.
  • zzrzzr
  • zzrzzr
04 Aug 2025 07:53
Replied by zzrzzr on topic PlasmaC Voltage Divider
Category: Plasmac
Thanks.
I tried 3mm thick steel and attached the clamp directly to the metal and it cut as it should.
When I do a torch-test with 3 seconds pulse then I read a voltage of 180V on the plasmac-screen. Is that a plausible value ?
Is it possible to get a table with cutting-settings for different thicknesses from sb. who also uses a Stahlwerk-Plasmacutter or comparable so I don't neet to try and waste so much metal ?
  • unknown
  • unknown
04 Aug 2025 07:49
LinuxCNC randomly crashes reportedly due to Python bug
Unexpected realtime delay on task 0 with period 1000000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
Starting DISPLAY program: qtvcp
hm2/hm2_7i95.0: Smart Serial port 0: DoIt not cleared from previous servo thread. Servo thread rat.sserial.0.fault-count pin will indicate if this is happening frequently.
The error log has identified an issue (noted above), you will need to address this.
  • matasbuk
  • matasbuk
04 Aug 2025 06:32
Hello, I am running the master branch of LinuxCNC with QTLathe GUI. I have a Python component that reads the feed rate from linuxcnc.stat and further use that value in my C component. The machine seems to randomly hard crash and exit LinuxCNC fully. What could be the problem ar what could I change to solve this? Thank you in advance! I am attaching the Python and C components, .ini and .hal files and the error log.
  • Aciera
  • Aciera's Avatar
  • tsaG
  • tsaG
04 Aug 2025 05:42
Replied by tsaG on topic Probe Basic ATC Questions
Category: QtPyVCP
Thanks!
do you also have an idea for my second issue?
  • MaxEkb77
  • MaxEkb77's Avatar
04 Aug 2025 03:24
Replied by MaxEkb77 on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
Lichuan strange company i buy at aliexpress & receive a water damaged garbage and no one wants to be responsible for it.
Displaying 13951 - 13965 out of 14203 results.
Time to create page: 2.981 seconds
