  • robocidalmaniac
  • robocidalmaniac's Avatar
15 Nov 2024 19:52 - 15 Nov 2024 19:52
Replied by robocidalmaniac on topic scorbot-er-3
scorbot-er-3
Category: Installing LinuxCNC
If anyone is interested I now have a Logitech Dual action F310 controller working as a pendant in LinuxCNC for the Scorbot ER 3 Robotic Arm. I can post if anyone is interested.
  • bnet
  • bnet's Avatar
15 Nov 2024 19:42
Fanuc Serial Pulse Coders - Red cap servos, mesa 7i76e, how to?
Category: Driver Boards
Great, yes I have an unused 7i97. Let me know if you need any other info.
Thanks!
  • PCW
  • PCW's Avatar
15 Nov 2024 19:28
Replied by PCW on topic coolant mist pulses
coolant mist pulses
Category: QtPyVCP
LinuxCNC/HAL is very powerful and customizable once you get
over the learning curve, looks like you are getting there...
15 Nov 2024 19:26
Replied by tommylight on topic LinuxCNC for lathe questions
I also like Axis a lot, it is like a duck = calm and easy on the surface but beating like hell underneath! :)
15 Nov 2024 19:19
Replied by tommylight on topic Only one of the gantry joints move
Category: Basic Configuration
Again, you have one motor spinning in the wrong direction on Y axis, did you check that?
  • Ismacr63
  • Ismacr63
15 Nov 2024 19:01
Replied by Ismacr63 on topic coolant mist pulses
coolant mist pulses
Category: QtPyVCP
Another trick would be to sidestep the "not" issue
and use another (hopefully unused) function to get
the not functionality:
loadrt siggen
addf siggen.0.update servo-thread
setp siggen.0.frequency .1     # 10 second period)
loadrt oneshot
addf oneshot.0 servo-thread
setp oneshot.0.width 2           # 2 second on time
loadrt logic personality=2050
addf logic.0 servo-thread
setp logic.0.in01 true
net cool-trigger siggen.0.clock oneshot.0.in
net coolant-out oneshot.0.out [some_parallel_port_pin]
net coolant-on logic.0.in-00
net gate-coolant logic.0.nand  oneshot.0.reset siggen.0.reset  # when coolant is off, reset both siggen and oneshot
also note that "coolant-on" is a made up signal name, you need to replace it with the actual
signal name used in your configuration for this function
I made it work with the "NOT"
I changed
Loadrt not for loadrt not count=3 in main hal.
In postgui hal I have commented loadrt not
I also realized that I didn't change the name of "coolant-on" to the one in my configuration.
Now it works perfect.
What for any of you is a minute for me turns into days T_T
but I really like it because I'm learning a lot about linuxcnc.
thank you very much for the help.
  • PCW
  • PCW's Avatar
15 Nov 2024 18:36
coolant mist pulses
Category: QtPyVCP
loadrt siggen
loadrt oneshot
  • PCW
  • PCW's Avatar
15 Nov 2024 18:23
coolant mist pulses
Category: QtPyVCP
Yes, there's another "not" component instantiated somewhere.
probably best to change the loadrt not command in the main hal
file so it instantiates all the "not" components needed
  • langdons
  • langdons's Avatar
15 Nov 2024 18:20
How to configure pause/resume over pin 10 of parallel port?
Category: HAL
Pin 17 is an input on the breakout board.
It is an output on the PC.
(Technically, it is bi-directional)
yyao.ca/projects/ParallelPortLinux/
  • Ismacr63
  • Ismacr63
15 Nov 2024 18:11
coolant mist pulses
Category: QtPyVCP
I've tried several mods but unfortunately I keep getting an error.
  • Aciera
  • Aciera's Avatar
15 Nov 2024 17:46
Replied by Aciera on topic coolant mist pulses
coolant mist pulses
Category: QtPyVCP
[qtpyvcp.app.launcher][[36mINFO[0m] Loading POSTGUI_HALFILE: /home/ismael/linuxcnc/configs/Fresadora1/probe_basic_postgui1.hal (launcher.py:96)
not: already exists
Make sure you don't have another 'addf not.0 servo-thread' in your 'probe_basic_postgui1.hal'. If you do you need to use another number (eg 'not.1')
  • PCW
  • PCW's Avatar
15 Nov 2024 17:40
Replied by PCW on topic Suggestion for a PCI EPP card for 7i43
Supposedly the Sunix based cards are OK for EPP mode
(the NetMOS 9805 based PCI cards do not implement EPP properly so can never work)
  • Aciera
  • Aciera's Avatar
15 Nov 2024 17:36
Interface to LightBurn (is pylib a better choice).
The python interface is the solution of choice for GUI development and easier to get support. linuxcncrsh is a bit of an exotic solution that few users have experience with.
You can run multiple python scripts that interface with the python API but you need to be aware that having more than one interface sending commands to linuxcnc can lead to race conditions, particularly when sending MDI commands (This is independent of what languages those interfaces use though).
With python you also need to be careful as one python script can block all the others (eg if you wait for an MDI command to finish execution) which can lead to problems like these :
github.com/LinuxCNC/linuxcnc/issues/3120
github.com/LinuxCNC/linuxcnc/issues/3129
  • juliankoenig87
  • juliankoenig87
15 Nov 2024 17:33
Replied by juliankoenig87 on topic Suggestion for a PCI EPP card for 7i43
Yes. Tried it before. Might be a faulty 7i43. Or I shoul test with an old pc with an "real" parport.
  • Ismacr63
  • Ismacr63
15 Nov 2024 17:27
coolant mist pulses
Category: QtPyVCP
Yes, all this will work on a parallel port.
something like this:
loadrt siggen
loadrt oneshot
loadrt not
net coolant-on not.0.in
net gate-coolant not.0.out oneshot.0.reset siggen.0.reset  # when coolant is off, reset both siggen and oneshot
Tried to test it but received an error. If I remove the lines that I have added in hal linuxcnc starts normally
Displaying 21886 - 21900 out of 22555 results.
Time to create page: 0.387 seconds
